LCA filter query sometimes has a problem
Solved455 views13th June 2025
Davor Joleski [DevOps Enabler]743 12th June 2025 0 Comments
Hi guys
When I edit the filter query of a component, for example a table, it doesn't give me the result. I need to randomly change something that I don't even know what it is so that that component will appear.
Davor Joleski [DevOps Enabler] Selected answer as best 13th June 2025
Wout Mahieu [SLC] [DevOps Catalyst]11.53K Posted 13th June 2025 1 Comment
Hi Davor,
When linking something to data from a component, you have to make sure something in the component is selected. Otherwise, the component will indeed not show up in the data dropdown. In this case, selecting a row in table 15 will make the component show up in the data dropdown.
This is a limitation of the current data linking framework. We are working on improving this behavior and make all data always available in the linking popup.
Davor Joleski [DevOps Enabler] Posted new comment 13th June 2025
Davor Joleski [DevOps Enabler] commented 13th June 2025
Thank you Wout Mahieu
