LCA – error trapped for concatenation
Solved2.30K views24th October 2023
Miloš Sedláček [DevOps Advocate]756 20th October 2023 0 Comments
Hello,
I'm manipulating the columns in my LCA - the goal is to get rid of the "," (comma) in the column UDP PORT. So I'm creating columns PRIOR and AFTER using regexp column manipulation. See the table
As the final step I use the concatenate manipulation method to glue PRIOR and AFTER together to achieve the goal. However, I'm experiencing the "Error trapped: An item with the same key has already been added."
Is it a bug or can I do something better?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 24th October 2023
Miloš Sedláček [DevOps Advocate]756 Posted 23rd October 2023 0 Comments
Hi Sebastiaan,
here is the entire query:
The Dataminer version is this:
Miloš Sedláček [DevOps Advocate] Answered question 23rd October 2023
