LCA – AdHoc data source from element parameter
Solved1.77K views23rd January 2025adhoc GQI lowcodeapps
MAXIMILIANO FILHO [DevOps Enabler]1.10K 4th September 2024 1 Comment
Hello,
I want to retrieve an standalone parameter value from an element to use as data source for an AdHoc. How can I do this?
Thanks,
MAXIMILIANO FILHO [DevOps Enabler] Selected answer as best 23rd January 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 23rd January 2025
Koen Bouckhout [SLC] [DevOps Advocate]1.68K Posted 5th September 2024 0 Comments
Hi Maximiliano,
It is possible to use a standalone parameter displayed in a certain visualization as feed in another component including an ad hoc Data Source. This can be done clicking the link item on the input of your ad hoc Data source.  Example below.  The feed dropdown will show all available feeds on the dashboard or App which can be used as input for your data source.
Is that what you are looking for?
Koen Bouckhout [SLC] [DevOps Advocate] Answered question 5th September 2024
