Kibana – How to search for results greater than or smaller than a certain TimeOfArrival
Solved2.20K views10th July 2023Elastic Elasticsearch Kibana
Alexander Verriest [SLC] [DevOps Advocate]754 2nd September 2020 0 Comments
I can search in Kibana for entries with a particular timestamp:
GET dms-info/_search
"query": {
"match": {
"TimeOfArrival" : "2020-06-30T13:19:36Z"
But how can I change this query so instead of "match", I get all results that came after this TimeOfArrival?
Brent Alleweireldt [SLC]2.74K Posted 2nd September 2020 0 Comments
To achieve this you have to use the range query (see: Kibana docs)
As example:
“query”: {
“range”: {
“TimeOfArrival” :
"gt":“2020-06-30T13:19:36Z”
