Keep track of the creation and removal of services and elements.
Solved2.68K views1st September 2023Element Creation element removal notifications service creation service removal
Simone Rosignoli41 24th August 2023 0 Comments
Hi All,
Is it possible to set up a correlation rule that will send me an email notification whenever a new service or element is added or removed from the system? I would like the email to contain the name of the service/element as well as the user who made the change. Can this be done?
Can you tell me how implementing this check will affect the system load?
Thanks
Simone
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 1st September 2023
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 24th August 2023 0 Comments
Hi Simone,
While the answer provided by Miguel, is the correct approach, for me that didn't work.
As an alternative I changed my filter, to filter out the correct information events using a regex.
Please find the full example below:
