Jobs – Group of fields within a Section
Solved4.03K views7th July 2020jobs
7
Bruno Dias [SLC] [DevOps Member]2.39K 18th June 2020 0 Comments
I would like to have a group of parameters related to the Video Encoders/Decoders in my Section "Transmission & Circuits". Even better if they have a dependency (only show the Bitrate / Nr of Streams if IP Video Decoder = Yes).
Currently, we have a field to each thing:
IP Video Decoder (Yes/No)
IP Video Decoder Bitrate (numeric)
IP Video Decoder Nr of Streams (numeric)
Has anyone done this before?
Bruno Dias [SLC] [DevOps Member] Selected answer as best 7th July 2020
Leander Druwel [SLC] [DevOps Member]2.11K Posted 23rd June 2020 0 Comments
Another option could be to create a separate section into your job configuration, specifically to enter one or multiple decoding profiles. That allows the end user who is entering the job information to decide whether none, one or even multiple decoding instances should be added to this job.
The configuration of how a job needs to look like is extremely flexible and allows you to add any field. Moreover, a specific section can be configured to allow multiple instances.
The result for the end user adding the job is following, allowing them to choose the number of decoding instances to a single job:
Note that previous comments made by Steven is indeed best practice, as it guides the users entering the job to more easily just select one of the allowed profiles. This information is translated to actual values when the job is (automatically) converted to a booking.
Leander Druwel [SLC] [DevOps Member] Answered question 23rd June 2020
