Issues with Reports when delete failover
Solved1.35K views14th July 2023
Jose Araujo [DevOps Advocate]1.01K 24th May 2022 0 Comments
Servers were separated in failover, however, the reports stopped working since they are pointing to the virtual IP that no longer exists, how can we delete all traces of the failover? I eliminate the TAGs in the DMS.XLS, after restarting it returns to failover configuration will appear.
Only have .25 server in standalone.
I get this error:
Thanks
Edson Alfaro [SLC] [DevOps Advocate]1.76K Posted 24th May 2022 0 Comments
Hi Jose,
As the failover config is still present so it's possible that some ASP config is still looking for the virtual IP.
I would recommend to mark the check box in the failover pop-up to "activate" it, un-check it and it will ask if you want to delete config or disable, click "YES" to delete it.
Then restart the DMA and you shouldn't see any errors in the SLAspConnection log.
