Issues with Failover NIC
Solved1.88K views28th May 2024Failover
-1
Jose Araujo [DevOps Advocate]1.01K 11th November 2023 4 Comments
HI,
After restart DMA appear alarm in failover, I test all Nic and are working OK, for some reason appear cable unplug, all cable and port is UP.
any help?
Thanks
Jose
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th May 2024
Ive Herreman [SLC] [DevOps Enabler] commented 13th November 2023
Hi Jose,
It seems the image is not visible in your question.
Can you please edit the question and upload the image again?
Jose Araujo [DevOps Advocate] commented 7th December 2023
Here find the image.
https://ibb.co/Km6DyCJ
Marieke Goethals [SLC] [DevOps Catalyst] commented 29th January 2024
Hi Jose,
When I try to access this link, I get a page that says “That page doesn’t exist”. Could you try to add the image in a different way?
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th May 2024
As this question has been inactive for a long time, we will now close it. If you want further assistance, feel free to post a new question or contact techsupport@skyline.be.
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 7th December 2023 2 Comments
I see that this question has been inactive for some time. Do you still need assistance with this? If yes, could you edit your question (via the cogwheel icon in the lower left corner of the question) and add the missing image? If not, could you select this answer so that this question is closed?
Hi, still persist the issue.
Marieke Goethals [SLC] [DevOps Catalyst] commented 7th December 2023
We need more information in order to be able to help you here. The image you posted above is not visible, so could you edit the question and add it again, or add it in another answer? Alternatively, you can also contact techsupport@skyline.be for assistance.
