Issues with Failover
Solved1.72K views28th March 2025
Jose Araujo [DevOps Advocate]1.01K 12th August 2024 2 Comments
HI,
I have issues with failover, all cables are connected and work ok, but for some reason in failover, 1 NIC is unavailable.
Saludos
Jose Araujo
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th March 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 23rd January 2025
I see that this question has been inactive for some time. Do you still need help with this? If not, could you select the answer (using the ✓ icon)?
Marieke Goethals [SLC] [DevOps Catalyst] commented 28th March 2025
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.40K Posted 12th August 2024 2 Comments
Find some FAQs on what happens if a network cable is pulled out of one of the DMA network cards?
If everything checks out cable wise, another check you can do is run “ipconfig -all” in command prompt and pull up the IP address returned for the NIC 1 interface. Is it the same IP address configured in Dataminer? Perhaps something has changed there.
Jose Araujo [DevOps Advocate] commented 12th August 2024
This behavior happens all the time when reboots the server.
Wale Oguntoyinbo [SLC] [DevOps Advocate] commented 13th August 2024
With that additional context, Its best to follow this up with our support team ( techsupport@skyline.be ) to help investigate this further.
