Issues visualizing ValidationText and ValidationState in Interactive Automation Script
Solved869 views26th June 2025automation scipt IAS
sofia nadramia [SLC] [DevOps Member]277 31st January 2025 0 Comments
Hi everyone,
I’m working on an Interactive Automation Script (IAS) to provision elements, and I’m running into an issue with the ValidationText and ValidationState properties. I expect the text box to indicate an error (e.g., highlight in red, display error text under textbox) when certain validation conditions fail, but that’s not happening.
Here’s the snippet:
if (NewViewCheckBox.IsChecked)
if (string.IsNullOrEmpty(ViewTextBox.Text))
engine.Log(“validation failed: View input string is null or empty”);
ViewTextBox.ValidationText = “Please Enter a View Name.”;
ViewTextBox.ValidationState = UIValidationState.Invalid;
isValid = false;
However, even though the validation logic executes (as seen in the logs), the dialog does not reflect the error visually:
  • The ValidationText does not appear.
  • The text box does not turn red or indicate an error.
I’ve attached screenshots of my UI, logs, and code for context. Any help in understanding why the validation feedback isn’t showing would be greatly appreciated!
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 31st January 2025 1 Comment
Hi Sofia,
This only works on the web version of the interactive automation scripts.
As a test, can you create a low-code app and trigger the interactive script there?
Peter Vanpoucke [SLC] [DevOps Advocate] commented 3rd February 2025
These options are indeed only released for the web version. There's an item on the Automation and Orchestration backlog to update the documentation of these properties.
