Issues after deploying Cube using MSI file
Solved1.82K views4th December 2025cube client Cube Launcher DataMiner Cube
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.36K 18th October 2024 0 Comments
I’d like to ask some help with this investigation.
A user needs to install Cube across several computers using the MSI file instead of the EXE because the users do not have permission to run executables in those computers.
After installing the package located on the local DMA at `C:\Skyline DataMiner\Webpages\Tools\Installs\DataMiner Cube.msi`, he gets the following error:
This screenshot shows the file we used:
We installed DataMiner Cube - MSI CefSharp v96 - DataMiner Dojo but still getting the same error.
Here is the documentation consulted so far. It does not explain the error we are seeing:
  • Question regarding Cube App Launcher - DataMiner Dojo
  • Installing the DataMiner Cube desktop application | DataMiner Docs
  • DataMiner Cube deployment methods | DataMiner Docs
  • New Cube - install one instance for all users - DataMiner Dojo
Moreover, since technicians will need to use Cube to connect to different versions of DataMiner, I’d like to confirm that this method we are using referred to as ‘MSI Launcher (shared)’ does support having more than one version installed in the same machine as indicated in Shared MSI installation method.
How do we proceed from here ?
Sam Stump [DevOps Advocate] Answered question 4th December 2025
Samuel Gagné [DevOps Member]129 Posted 23rd October 2024 1 Comment
Is there a webpage where we can access the different MSI versions available ? How do we know the exact MSI versions needed for both the server versions we have, is there some sort of compatibility table ?
We currently have the following versions, from two different clusters : 10.4.0.0-14003 & 10.1.6.0-10449.
As I understand, we would need to have two different MSI installed on the same device to be able to connect to both clusters. Is there a way to retrieve exactly the versions necessary for those two ?
Miguel Barquet [SLC] [DevOps Advocate] Posted new comment 23rd October 2024
Miguel Barquet [SLC] [DevOps Advocate] commented 23rd October 2024
To complement what Samuel said, he downloaded the file `C:Skyline DataMinerWebpagesToolsInstallsDataMiner Cube.msi` from the 10.4 DMA and still got an error that reads “the required version is not available.”
Also, can you please confirm he’ll be able to use the MSI Launcher (shared) method to access DataMiner server version 10.1.6.0-10449? Here is the information I found, but still not clear to me https://docs.dataminer.services/user-guide/Getting_started/Accessing_DataMiner/Accessing_DataMiner_Cube/Installing_DataMiner_Cube/DataMiner_Cube_deployment_methods.html#overview
