Issue with installing dmapp with dashboard
Solved534 views5th November 2025dmapp
Danijel Briški [SLC] [DevOps Advocate]98 10th July 2025 0 Comments
After creating a dmapp package with dashboard and GQIs, I was not able to install it due to this error:
After removing GQIs the issue persists, which suggests that the problem is related to dashboard.
Wout Mahieu [SLC] [DevOps Catalyst]11.53K Posted 15th July 2025 0 Comments
Danjiel,
It is hard to say what exactly is going wrong when looking at the error in the screenshot. I suggest you get into contact with tech support to investigate this further.
