Issue with Automation Script: Constructor Argument Error in DM Version 10.3.0.0-13184
Solved2.76K views14th May 2025Alarm Console Automation script SLNetClientTest tool
A B M Sidddique [DevOps Advocate]411 2nd October 2024 1 Comment
Hello Dojo Community !
I have been working on an automation script with additional logic to clear out week old Correlated warning alarms that have their ‘auto-clear’ functionality disabled. The original script was kindly provided by Joachim from Dojo community :
SLC-AS-ClearNoticeAlarmsOlderThanAWeek/Clear Notice Alarms Older Than A Week_1/Clear Notice Alarms Older Than A Week_1.cs at master · SkylineCommunications/SLC-AS-ClearNoticeAlarmsOlderThanAWeek (github.com)
previous question : Method of Clearing Alarms from the alarm console using an Automation script – DataMiner Dojo
I’ve managed to select and filter the necessary alarm properties (AlarmID, Element ID, Hosting ID, Source, Value) using the SLNet Client tool. However, after executing the provided script in Visual Studio and testing in Cube AS validation, I encountered errors.
It appears that one of the arguments I’m passing isn’t correct. I receive an error stating the constructor takes 4 arguments in the format (int, int, int, string). Given that our DM version is 10.3.0.0-13184, I suspect that some .NET methods might behave differently. Also the Alarm is not getting cleared as expected (manually we do this by right click on the alarm and selecting the option ‘clear alarm’)
Could anyone kindly help me identify which argument might be incorrect and suggest how to adapt the script for my environment? I’d appreciate any guidance on fixing the issue so that the script clears the alarms as expected.
Thank you for your continued support!
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 14th May 2025
Marieke Goethals [SLC] [DevOps Catalyst] commented 14th May 2025
As this question has now been inactive for a long time, I will close it. If you still need assistance with this, could you contact tech support? For more info, see https://docs.dataminer.services/user-guide/Troubleshooting/Contacting_tech_support.html
Tom Waterbley [SLC] [DevOps Enabler]10.29K Posted 2nd October 2024 12 Comments
Hi, version 10.4.9 of the Skyline.DataMiner.Dev.Automation NuGet package is referenced in the C# project on this line. Since you are using an older DataMiner version, it would be better if version 10.3.0.21  is referenced instead. This can also be changed using the package manager in Visual Studio.
After changing the version, you should see that an error is shown in Visual Studio if something doesn’t exist yet in the older NuGet package.
The problem seems to be that the “TreeID” property is missing on the alarms. I think this can be solved as follows (untested):
var clearingMessage = $”Cleared the alarm with TreeID ‘{alarm.DataMinerID}/{alarm.RootAlarmID}’ from Automation.”;
SetAlarmStateMessage setAlarmStateMessage = new SetAlarmStateMessage(alarm.DataMinerID, alarm.RootAlarmID, (int)Skyline.DataMiner.Net.Enums.AlarmUserStatus.Clear, clearingMessage);
engine.SendSLNetMessage(setAlarmStateMessage);
A B M Sidddique [DevOps Advocate] commented 3rd October 2024
Thank you Tom for your advice and i have downgraded the Nuget package to 10.3.0.2. I just wanted to know , if the (int)Skyline.DataMiner.Net.Enums.AlarmUserStatus.Clear, // Clear Status
Would this argument work to the version to clear the alarm or should I use something else ? execution is successful with no error but the alarm is not clearing
Tom Waterbley [SLC] [DevOps Enabler] commented 3rd October 2024
Hi, could you please try using value ‘7’ instead of the enum as value for the third argument? But that should be the same, and according to what I can find in other examples it should work.
Hi Tom ,
Thank you for your help , using ‘7’ instead of enum , SLNET is able to create the message . Out of curiosity is there a way / method to directly clear the alarm from the alarm console ( as we do manually by right clicking on an alarm and select ‘clear alarm”) rather then SLNET client tool as I realized some of our servers /DMA we work on are not owned by us but still have admin privilege’s to utilize Cube but may not have the ability to run SLNET client tool, so might face issue on that.
Tom Waterbley [SLC] [DevOps Enabler] commented 4th October 2024
Hi, SLNet client test tool uses the same type of connection of Cube, with the same previleges. So you should be able to perform the actions on those DMAs as well. Please always be careful when doing things with the test tool though.
A B M Sidddique [DevOps Advocate] commented 7th October 2024
Hi Tom,
I have been trying to troubleshoot it but we are still receiving the same error :
” Failed to clear alarm with RootAlarmID ‘127510621’. Error: You don’t have permission to perform this action.
(Script ‘Clear Notice Alarms Older Than A Week’)”
“2024/10/07 08:16:20.086|SLAutomation.exe 10.3.2243.12260|16140|25728|CSharp|DBG|5|(Script Clear Notice Alarms Older Than A Week/2) Extended Error Info:
(Code: 0x80131500) Skyline.DataMiner.Automation.ScriptAbortException: RunSafe|Something went wrong.
at Skyline.DataMiner.Automation.Engine.ExitFail(String reason)
at ClearNoticeAlarmsOlderThanAWeek_1.Script.RunSafe(IEngine engine)
at ClearNoticeAlarmsOlderThanAWeek_1.Script.Run(IEngine engine)
2024/10/07 08:16:20.086|SLAutomation.exe 10.3.2243.12260|16140|25728|CScriptLoader::ExitNow|DBG|-1|[ABM Siddique] (Script Clear Notice Alarms Older Than A Week) EXIT: “RunSafe|Something went wrong.”
2024/10/07 08:16:20.087|SLAutomation.exe 10.3.2243.12260|16140|25728|CScriptLoader::FinalActions|DBG|3|[ABM Siddique] (Script Clear Notice Alarms Older Than A Week) Script execution FAILED
2024/10/07 08:16:20.087|SLAutomation.exe 10.3.2243.12260|16140|25728|CAutomation::Execute|INF|0|[ABM Siddique] Finished executing script: ‘Clear Notice Alarms Older Than A Week’ (ID: 174) – FAILED – Execution took 00.394s.”
I believe it is because of the DMA server restrictions we have that is not allowing to go through with the script action (have DM admin privileges’). Thank you
Show 7 more comments
A B M Sidddique [DevOps Advocate]411 Posted 28th January 2025 5 Comments
namespace ClearAllActiveAlarms
using System;
using System.Linq;
using System.Threading.Tasks;
public class Script
try
engine.GenerateInformation(“Script starting.”);
ClearAllAlarms(engine);
engine.GenerateInformation(“Script ending.”);
catch (Exception e)
engine.ExitFail(“Run|Something went wrong: ” + e);
private void ClearAllAlarms(IEngine engine)
try
engine.GenerateInformation(“Fetching all active alarms to clear.”);
var messages = GetActiveAlarms(engine);
if (messages == null || messages.Length == 0)
engine.GenerateInformation(“No active alarms were retrieved.”);
return;
engine.GenerateInformation($”Received {messages.Length} messages from the DataMiner system.”);
ProcessActiveAlarms(messages, engine);
catch (Exception ex)
engine.GenerateInformation($”ClearAllAlarms|Something went wrong: {ex.Message}\n{ex.StackTrace}”);
engine.ExitFail(“ClearAllAlarms|Something went wrong.”);
private DMSMessage[] GetActiveAlarms(IEngine engine)
try
var getActiveAlarmsMessage = new GetActiveAlarmsMessage();
return engine.SendSLNetMessage(getActiveAlarmsMessage);
engine.GenerateInformation($”Failed to retrieve active alarms: {ex.Message}”);
return null;
private void ProcessActiveAlarms(DMSMessage[] messages, IEngine engine)
var oneWeekAgo = DateTime.UtcNow.AddDays(-7);
foreach (var message in messages)
if (message is ActiveAlarmsResponseMessage alarmMessage)
Parallel.ForEach(alarmMessage.ActiveAlarms, alarm =>
if ((alarm.Severity == “Notice” || alarm.Severity == “Warning”) && alarm.RootCreationTime > oneWeekAgo)
ClearSingleAlarm(alarm, engine);
else
engine.GenerateInformation($”Skipping Alarm {alarm.RootAlarmID} with Severity ‘{alarm.Severity}’ or CreationTime ‘{alarm.RootCreationTime}’ not matching criteria.”);
else
engine.GenerateInformation(“Received a message that is not an ActiveAlarmsResponseMessage. Skipping…”);
private void ClearSingleAlarm(AlarmEventMessage alarm, IEngine engine) // Updated type
try
engine.GenerateInformation($”Clearing Alarm {alarm.RootAlarmID} with Severity ‘{alarm.Severity}’ and Source ‘{alarm.Source}’.”);
var clearingMessage = $”Cleared the alarm with DataMinerID ‘{alarm.DataMinerID}’ and RootAlarmID ‘{alarm.RootAlarmID}’ from Automation.”;
var setAlarmStateMessage = new SetAlarmStateMessage(
alarm.DataMinerID,
alarm.RootAlarmID,
7,
clearingMessage
engine.GenerateInformation($”Alarm with RootAlarmID ‘{alarm.RootAlarmID}’ cleared.”);
engine.GenerateInformation($”Failed to clear Alarm {alarm.RootAlarmID}: {ex.Message}\n{ex.StackTrace}”);
Mohan Ramasamy Veerappan [DevOps Member] Posted new comment 23rd July 2025
Jorge Dias [SLC] [DevOps Enabler] commented 29th January 2025
Hi, you get the error for alarms that are in warning state correct?
Those alarms cannot be cleared, only alarms that are in Normal state can be cleared, should be the same in the alarm console, the option Clear Alarm… should only be displayed when the alarm return to Normal state.
Can you please check if this is the case? Otherwise could you show screenshot of the alarm console with the alarm that you want to clear and the information events generated by the script?
A B M Sidddique [DevOps Advocate] commented 29th January 2025
Hi I am clearing out warning and notice alarms that are generated by correlation rule which are clearable, so the script checks for the last seven days if there are these severity of alarms and then sends the command to SLNET to clear / change to normal. The alarms that cannot be cleared are not cleared ( original intention) this runs on a scheduled basis daily on our system to tidy up the alarm console.
Mohan Ramasamy Veerappan [DevOps Member] commented 26th March 2025
Could @Tom Waterbley or anybody tell me where can I find the value "7" for the state "Clear" and also for the other State values listed please.
@Mohan, could you create a separate question for this? As this is a comment on an older question, it is likely that it will no longer get noticed by our content experts.
Mohan Ramasamy Veerappan [DevOps Member] commented 23rd July 2025
Okay, Sure. Thanks.
