Issue while exporting/importing elements from 9.6 to 10.3
Solved2.84K views19th July 20239.6 Import CSV
Carolina Costa [SLC] [DevOps Advocate]1.03K 27th June 2023 0 Comments
Hello DataMiner community,
We are planning to do a transfer of the Views and some elements from a system (using DataMiner version 9.6) to a new setup using 10.3.
Regarding the elements, we could already successfully transfer some of them, but we found a couple of issues that we would like your insights.
When importing the ExportData.csv file containing the elements to be created, besides changing the dataminer ID and removing the element IDs, we noticed that from 9.6 to 10.3, there are some differences in the header of the csv file. Namely, in the newer version there were added the following headers: ReplicationMaxBuffer,ReplicationMinBuffer,ProtocolType,CredentialGUID,TLS,AllowedIpAddresses,ConnectTimeoutTime.
Besides that, we couldn’t find any differences between the two headers (neither on naming nor on sorting).
After this brief overview, I am now finding and blocked with an issue:
  • When importing elements with more than one connection (2 SNMP and 1 SSH in this case), the first connection works just fine, but the other ones don’t get correctly filled (they are missing the IPs, ports,…). For this one, I suspect that there is a shift in the csv file that it is causing the loss of all the configuration for the other connections. I did a comparison from an export from 10.3 and the export from 9.6, but besides some custom properties and trend/alarm templates, I cannot find what is shifted.
Does anyone already did this and knows what it might be wrong and how can I fix it?
João Severino [SLC] [DevOps Enabler]14.78K Posted 27th June 2023 3 Comments
Hi Carolina,
Not sure if this can help but have you tried the following from this link in the documentation?
Carolina Costa [SLC] [DevOps Advocate] commented 27th June 2023
Hello João, thanks for your reply. In this case, I am not doing any change in Excel, so I do not expect any issues related to this.
Bing Herng Chong [SLC] [DevOps Advocate] commented 28th June 2023
Hi João, thanks for calling this out. We are close to being able to import a .csv entry from 9.6 into 10.3. But some manual manipulation of the .csv file is required as described in the original post.
Carolina and I noticed that for some SNMPv3 values, these are exported under columns that are labelled with fields meant for Serial connections. Because I cannot import a picture into this comment, I’ll make another post describing what we observed below. Are you able to help identify the SNMPv3 fields? Some we can guess but it would be good to get it right the first time.
João Severino [SLC] [DevOps Enabler] commented 28th June 2023
Hi Bing, in certain instances some columns are repurposed depending on the type of connection the element uses, however, I cannot immediately find it documented exactly what fields are used for SNMPv3 but I can try to look a bit further and get back to you.
Koen Annys [SLC] [DevOps Advocate]144 Posted 27th June 2023 1 Comment
I believe the feature “export elements to .dmimport file” will be more beneficial to you. This method e.g. will allow you to extract trend and alarm data as well.
More info can be found here.
Carolina Costa [SLC] [DevOps Advocate] Posted new comment 27th June 2023
Hello Koen, thanks for your reply. In this case, I don’t think a dmimport will be the best option, as we don’t want to migrate the elements. We want new element IDs with the same configuration. Another issue with this approach is that the credentials will get lost, while we were using the credentials GUIDs in the csv (from the credentials library) to get the credentials.
Bing Herng Chong [SLC] [DevOps Advocate]1.73K Posted 28th June 2023 1 Comment
*** This is not an answer to the original post but an addendum to one of the comments above to the response from Joao ***
Hi Joao, on the left are headers and on the right are corresponding values. As you can see it appears we are reusing Serial fields for SNMPv3 values in the .csv export. What would be helpful to clarify is whether header on row 20 and 25 are reused for SNMPv3 values and if so what are they?
João Severino [SLC] [DevOps Enabler] Posted new comment 28th June 2023
Hi Bing, as I mentioned in my other comment I do not have a complete list of all columns that are used for SNMPv3 as these are mapped to some internal objects.
I did however gave it a try in creating a similar element in my localhost and in my case the Baudrate column contains 3 times the value 0 separated by tabs and the Bus Address just contains the tabs indicating to me that is likely not used for SNMPv3.
