Issue when using Trigger component
Solved461 views6th November 2025#automationscript LCA trigger
Hari priya Venkatesan [DevOps Advocate]1.06K 22nd September 2025 0 Comments
Hi Team,
I’m facing an issue with the trigger component. I have an ON/OFF button that is designed to turn on/off all the elements inside a truck.
  • Each time the trigger runs, and I then click the ON/OFF button, the input values mapped to the automation script are passed as empty.
  • When I switch ON/OFF another truck, the previous input values are being passed to the automation script instead.
  • If I remove the trigger, the ON/OFF functionality works as expected.
I’m unable to identify what’s causing this issue with the trigger.
Robin Debel [SLC] [DevOps Enabler]2.26K Posted 3rd October 2025 0 Comments
Hi Hari,
This looks and sounds like a software issue, please get in contact with tech support (support@dataminer.services) so they can look further into this issue.
