Issue “stylecop.json could not be found” in new Automation Script template
Solved1.79K views7th April 2025Automation script interactive automation script
Enis Abaza [SLC] [DevOps Advocate]361 4th April 2025 2 Comments
Hi everyone,
I’ve run into a bit of a challenge with the stylecop.json file in the new automation script template. When I create a fresh “Data Miner Automation Script Project,” I encounter this error right away:
Source file ‘C:\Users\EnisAB\source\repos\OrangeOceaneTicketingSystem\..\Internal\Code Analysis\stylecop.json’ could not be found.
Here is my view from the solution explorer, where you can see the location of the “stylecop.json” file:
The part of the error that I bolded out (“..\”) clearly causes the issue. So in the “Directory.Build.props” file I removed the “..\” that is causing the issue:
<Additional Files Include=“..\Internal\Code Analysis\stylecop.json”>
<Link>Properties\stylecop.json</Link>
</AdditionalFiles>
To this:
<Additional Files Include=“Internal Code Analysis\stylecop.json”>
</AdditionalFiles>
This works for now, but the fix doesn’t stick, because whenever I restart my PC or close Visual Studio, the Directory.Build.props file gets regenerated, and my StyleCop rules disappear. I’m using DIS version 3.1.7.
I’m wondering if I might be missing something here. Is this a known issue with the new automation script template, or could it be a bug? Has anyone found a permanent workaround for this?
Enis Abaza [SLC] [DevOps Advocate] Selected answer as best 7th April 2025
Edib Šupić [SLC] [DevOps Enabler] commented 7th April 2025
Hi Enis,
Can you try reinstalling the DIS extension and when you do install the latest version 3.1.8?
Cheers
Enis Abaza [SLC] [DevOps Advocate] commented 7th April 2025
Hi Edib,
I reinstalled the DIS extension (version 3.1.8) as you suggested, but unfortunately, the error still persists.
Michiel Oda [SLC] [DevOps Advocate]3.90K Posted 7th April 2025 2 Comments
Hi Enis
When creating a new solution, you see the checkbox for ‘Place solution and project in the same directory’. This needs to be unchecked for DIS to work properly with the new templates. Unfortunately this is currently not possible to disable with the project templates.
Michiel Oda [SLC] [DevOps Advocate] commented 7th April 2025
The easiest to fix your scenario is to remove the solution and recreate it with the checkbox off.
Thank you Michiel for your response, it works when I uncheck the mentioned checkbox.
