Is there OVA for creating a DataMiner as a VM or AMI for creating DataMiner AWS EC2 instance?
Solved3.06K views12th January 2023AWS VM
Srikanth Mandava [SLC] [DevOps Advocate]936 4th September 2020 0 Comments
I have installed DataMiner on my laptop and wondering there are automated way of installing the product as VM or cloud instance?
Srikanth Mandava [SLC] [DevOps Advocate] Selected answer as best 12th January 2023
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 4th September 2020 3 Comments
No there is not.
You do have the option to run the installer unattended.
Srikanth Mandava [SLC] [DevOps Advocate] commented 4th September 2020
Thanks Ive, is there a plan for such deployments in the future?
Sergio Abreu [SLC] [DevOps Member] commented 7th September 2020
Please see the comments on similar question.
question -> docker-dma-image
Meanwhile I gave it a try, creating a docker image and bump into the following error:
NAVIGATION —go to licensing—.
LICENSING — DataMinerInstallerV2.Steps.License.LicenseResult.
LICENSING — Failed. —.
Which might mean a new ISO unattended is needed for docker images?!?
But as Jan Staelens stated the biggest challenge is versioning and license.
Meaning, DMA licensing based on MAC address and unattended installation where the XML configuration expects user to know the IP in advance, makes all the setup quite tricky to play with docker or later on replicate and manage the deployments.
Also scaling (horizontally) DMS would need to be automated to bring extra value for such deployment proposition, among other aspects.
Alberto De Luca commented 13th October 2021
Found this post too – not for the laptop part, but about the cloud side:
DM built on DC2 nodes in AWS:
https://community.dataminer.services/question/any-experiences-with-the-installation-and-running-of-dmas-in-aws/
Alberto De Luca [DevOps Enabler]5.75K Posted 19th October 2021 0 Comments
Hi Sri, I believe there is an option to build a custom AMI under this section – but it would be at AWS admin level. Perhaps something can be saved with just the OS and management and polling NICs, and the DMA software to perform the build:
Theoretically, SL could build one that is available as a 3rd party option in AWS Marketplace or the community – however for a “built-DMA” AMI,some considerations may be needed with the licensing team (e.g. to allow the DMA to start when using the AMI on a different instance).
