Is there a way to prevent Not Initialized columns from breaking ClientSideRowFilter?
Solved1.40K views7th December 2021Visio Visual Overview
Gabriel Borges [SLC] [DevOps Advocate]769 19th November 2021 0 Comments
Hello Dojo,
We currently have a Visual Overview that uses ClientSideRowFilter on a view table and noticed that when one of the filtered columns have a Not Initialized cell, the row is never returned. Is there a way to prevent that from happening? Currently, the variable is initialized to empty, so should it be initialized to something else?
Thank you.
Gabriel Borges [SLC] [DevOps Advocate] Selected answer as best 7th December 2021
Toon Casteele [SLC] [DevOps Enabler]7.45K Posted 7th December 2021 0 Comments
The ClientSideRowFilter works similarly to the filter you can use at the top of the table in data display. I couldn't figure out a way to include "not initialized" or "not available" there either.
