Is there a way to get column data of Width=0 using GetTableForParameterFiltered?
Solved1.80K views18th October 2023WebAPI
Gabriel Borges [SLC] [DevOps Advocate]759 26th July 2023 0 Comments
Hello Dojo,
I am currently using the GetTableForParameterFiltered WebAPI call and the response is only returning the cell data of columns currently shown and not any columns where the driver has the width=0.
I have tried to update the table layout, but the same data is returned. I have also tried adding the Columns filter, but then nothing is returned. Is there another option to do so without updating the driver? The only way I was able to get the data is using the GetTableForParameterV2 call, but there is no indication what PiD the values are for.
Many thanks in advance.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 18th October 2023
Gabriel Borges [SLC] [DevOps Advocate]759 Posted 18th October 2023 0 Comments
We have decided to release a new version of the driver where the column width=100 and that exposed the value to the WebAPI. That was the only we were able to retrieve that value with the GetTableForParameterFiltered call.
