Is there a problem if I setup a failover DMA pair on different locations?
Solved1.78K views29th June 2021Failover
Sebastian Ulloa [SLC] [DevOps Advocate]2.30K 29th June 2021 0 Comments
I have seen that failover DMAs are in the same network as the main DMA, but I wonder if there is a problem if the failover DMA is in a different network/location from the main one.
If it is possible, is there a minimum required specification? e.g. latency between the two servers should be no greater than xx ms.
Sebastian Ulloa [SLC] [DevOps Advocate] Selected answer as best 29th June 2021
Ive Herreman [SLC] [DevOps Enabler]14.78K Posted 29th June 2021 4 Comments
At the time of writing, a pair of failover servers need to be in the same network (subnet).
However, in one of the upcoming releases, DataMiner will support failover for servers that are in a different subnet.
There are no requirements defined for latency, but less is of course better.
Ram Prakash [DevOps Member] Posted new comment 28th December 2022
Sebastian Ulloa [SLC] [DevOps Advocate] commented 29th June 2021
Thank you Ive!
Miguel Obregon [SLC] [DevOps Catalyst] commented 29th June 2021
Hi Sebastian,
As a reference, we manage to make a failover pair work over a satellite connection (Average latency around 700ms)
Leander Druwel [SLC] [DevOps Member] commented 30th June 2021
Adding a reference to our recommendations, including also network specs https://community.dataminer.services/dataminer-compute-requirements/
Note that following is recommended ‘As a rule, we recommend a throughput ranging from 100 Mbps to 1 Gbps and a latency ranging from < 50 ms to < 30 ms.'
Ram Prakash [DevOps Member] commented 28th December 2022
Hi SLC, team.. Is the situation still true? that we need to have the equipment in same subnet? or do we have option to use DNS with multiple IP addresses?
If using DNS, then is it required to change anything on the SNMP trap sending devices to point the server?
