Is there a driver to monitor both the Linux Platform and the Ilo Management Interface?
Solved1.91K views23rd November 2021
Kawssar Marzouk [DevOps Advocate]597 17th November 2021 0 Comments
In Microsoft Platform, there is a driver version 1.1.2.8 where we can monitor both the server from the TCP/IP and the ILO Management Interface via SNMP in order to see the HP Parameters (Physical Health Status of the server), We are looking for a driver version having the same concept in Linux Platform?
Kawssar Marzouk [DevOps Advocate] Selected answer as best 23rd November 2021
Philip Argent [DevOps Advocate]1.13K Posted 19th November 2021 2 Comments
Both the SNMP and SSH version of the Linux protocol support HP and DELL hardware monitoring. The SSH version has a second connection for SNMP for the hardware monitoring.
Kawssar Marzouk [DevOps Advocate] commented 21st November 2021
Thanks Philip for your answer, however, I still need advice; on the exact version of the Linux Platform SSH protocol which is having both the TCP/IP and SNMP Connections?
Philip Argent commented 22nd November 2021
1.0.1.x [SLC Main] is the main path for ssh, which includes hardware monitoring, the current version is 1.0.1.14
-1
Alberto De Luca [DevOps Enabler]5.75K Posted 19th November 2021 0 Comments
Hardware monitoring is a possibility for known agents (HP/DELL) as Phil recalls above. That’s all polled via SNMP.
One more thing worth considering is that in terms of iLO/iDrac, most of the networks scenarios I’ve come across would keep that traffic in O.O.B., i.e. lights-out management completely separated from your standard polling traffic – this might play a part in your architecture.
