Is it possible to use QA Class “Parameter” for parameter of type “read bit” ?
Solved2.70K views22nd April 2021QActions
Jurica Gajski176 21st April 2021 0 Comments
Hello,
Is it possible to use in QA Class “Parameter” for parameter of <type> read bit </type>? For example, instead of using parameter number ( protocol.GetParameter(147) ), I want to use
Class "Parameter" ( protocol.GetParameter(Parameter.name_147)). Try it but not work. In DIS, when editing QA there are no IntellySense possibilities in Class "Parameter" for parameters of "read bit" type. With other types of parameters Class "Parameter" working fine.
Maybe I declared something wrong in "read bit" parameters?
Thank you!
Jurica Gajski Selected answer as best 22nd April 2021
Pedro Debevere [SLC] [DevOps Enabler]3.46K Posted 22nd April 2021 0 Comments
The Parameter class only provides entries for parameters of type "read" or "write" (entries of the latter type are found under the Parameter.Write class).
For all other types, the QAction_Helper code will not generate entries under the Parameter class.
Pedro Debevere [SLC] [DevOps Enabler] Answered question 22nd April 2021
