Is it possible to use a protocol that is not in use as filter in dashboards?
Solved1.75K views8th March 2023Dashboards
7
Stijn Declerck [SLC] [DevOps Advocate]802 7th March 2023 2 Comments
In the Dashboards module, can you use a protocol that is not in use for filtering data?
The protocol is installed on the DMA.
I want to put a filter on a dropdown of all elements to only show the elements running that specific protocol. The value chosen in the dropdown determines of of which element the data is shown. The system is rather dynamic, elements are often deleted/created. So it is possible, like now, that there are no elements running the protocol and the dropdown doesn’t have any values.
Stijn Declerck [SLC] [DevOps Advocate] Selected answer as best 8th March 2023
Sebastiaan Dumoulein [SLC] [DevOps Enabler] commented 7th March 2023
Can you elaborate a bit more on the use case? Where do you want to use this protocol filter?
Stijn Declerck [SLC] [DevOps Advocate] commented 7th March 2023
I have updated the question.
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.48K Posted 8th March 2023 1 Comment
Hi Stijn,
We indeed only show the names (and versions) of protocols that are effectively used in the DMS. This is done to avoid having too many (unused) items in the list, so the user can focus on protocols that matter.
Potentially we could make it available to show all protocols (and versions), but this would require a software change. Feel free to create a new feature suggestion or task for this.
As a side note, it will be possible in the future to have the results of a GQI query in a drop down. With this you could feed elements to your state component as well.
Stijn Declerck [SLC] [DevOps Advocate] Posted new comment 8th March 2023
Stijn Declerck [SLC] [DevOps Advocate] commented 8th March 2023
Thanks for your reply!
7
Miguel Obregon [SLC] [DevOps Catalyst]22.41K Posted 7th March 2023 2 Comments
Hi Stijn,
As Sebastiaan mentioned, it will be nice if you can elaborate a bit more on your question. Assuming that you want to filter on elements, what you could do is the following:
  • Data source: Get elements
  • Select: Make sure that you include the columns Protocol and version protocolversion.
  • Filter on ‘Protocol’: Since the columns Protocol and version protocolversion are string type, you could use the options available for string types (equal, not equals, not contains, regex, …)
  • Filter on ‘protocolversion’: Similar case as the previous filter
Based on this you could retrieve the elements that are not using a specific driver version.
Hope it helps.
Pieter Van Compernolle [SLC] [DevOps Enabler] Posted new comment 19th April 2023
Hi Miguel, thanks for the reply.
This will indeed work with queries to show element properties, but I want to use the elements as feed for state parameters. It is not clear to me why it is not possible to select a protocol that is not in use, because it is possible in the queries.
Pieter Van Compernolle [SLC] [DevOps Enabler] commented 19th April 2023
Do note Stijn that you can use the protocol name as filter as well (instead of one or multiple specific versions). That will filter the list of elements to all elements having any version of that protocol (and any future version).
Not sure if that helps or not.
