Is it possible to trigger automation script from protocol without generating information event
Solved2.45K views28th October 2022Automation protocol
Tim Vandenbruwaene [SLC] [DevOps Member]2.28K 21st May 2021 0 Comments
From a protocol you can trigger an automation script, but everytime an information event “script started … by (NO_INFORMATION)” is generated.
Is there a way you can launch a script from a protocol QAction but without DataMiner generating the script started event?
If I’m not mistaken this is possible for doing a parameter set?
          SetParameterMessage setInfo = new SetParameterMessage();
          setInfo.DisableInformationEventMessage = true;
Gabriel Borges [SLC] [DevOps Advocate] Answered question 28th October 2022
Wouter Demuynck [SLC] [DevOps Advocate]7.04K Posted 21st May 2021 0 Comments
There’s currently no way to prevent the “Script Started” information event from being generated when starting an automation script.
Tim Vandenbruwaene [SLC] [DevOps Member] Selected answer as best 21st May 2021
Gabriel Borges [SLC] [DevOps Advocate]759 Posted 28th October 2022 0 Comments
Just came across this question looking for the same answer and did some investigating and it seems this is now possible with Dataminer 10.2.8 by adding the “SKIP_STARTED_INFO_EVENT:TRUE” script option.
https://intranet.skyline.be/DataMiner/Lists/Release%20Notes/DispForm.aspx?ID=33666
