Is it possible to play audio within Cube (Alert sound) when a major alarm is received?
Solved1.55K views18th February 2024Alert Audio Cube sound
David Merrifield [DevOps Member]937 8th February 2024 0 Comments
Simple question which probably has a simple answer? 🙂
Thanks!
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 18th February 2024
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 8th February 2024 1 Comment
This is indeed possible. You'll need to create a filtered tab showing only major alarms and then enable the audible alert option for that tab. (Note that you need to have Windows Media Player on the client machine for this.) You can find more information here: https://docs.dataminer.services/user-guide/Basic_Functionality/Alarms/Working_with_alarms/Working_with_the_Alarm_Console/Configuring_a_custom_alert_sound_for_an_alarm_tab.html
David Merrifield [DevOps Member] Posted new comment 19th February 2024
David Merrifield [DevOps Member] commented 19th February 2024
Amazing! thank you
