Is it possible to pass View ID to Web Component to open specific monitor page?
Solved1.33K views26th February 2025Dashboard component GQI queries
Steve Purcell [SLC] [DevOps Advocate]2.61K 25th February 2025 0 Comments
I have a GQI which collects desired Views and View IDs which the user is able to select.  I would then like to pass this as part of the URL to open a specific Monitor Page.
Web Component Settings Type is set to ‘WebPage’ with
URL set to ‘http://localhost/monitoring/view/@{View ID}/elements’
which causes an error “Cannot convert null to a value type”.
The idea is to pass the selected Views ‘View ID’ to the URL address, so the selected views element page opens.  Is this possible?
Steve Purcell [SLC] [DevOps Advocate] Selected answer as best 26th February 2025
Wout Mahieu [SLC] [DevOps Catalyst]12.27K Posted 26th February 2025 1 Comment
Hi Steve,
This is indeed possible using the Web component leveraging the data interpolation feature. You can use the DMAIP value and the View ID (from a table) to create the url: https://{URL.DMAIP.Value}/monitoring/view/{COMPONENT.”Table 2″.”Selected rows”.Views.ID} . The @ sign in your URL is redundant and is causing the error.
Note that you can also add ?embed=true at the end of the URL to make the header & sidebar dissapear.
Steve Purcell [SLC] [DevOps Advocate] commented 26th February 2025
Thank you Wout, this works great.
