Is it possible to override alarm TTL for a given driver?
Solved1.21K views11th July 2023
Bernard Pichot [SLC] [DevOps Advocate]1.32K 7th January 2022 0 Comments
in System settings/Time To Live it's possible to override TTL for trending parameters for a given protocol.
Is it possible to have similar TTL override for alarms ?
Does logger table can be implemented in the protocol to achieve such behavior ?
Jeroen Geldhof [SLC] [DevOps Enabler]5.50K Posted 7th January 2022 0 Comments
Hi Bernard, I believe a new feature will be needed for this.
It would indeed be interesting to also allow overwriting the TTL for alarms on a protocol level.
