Is it possible to hide in Visio “Not Monitored” parameter
Solved1.62K views15th January 2024MS Visio
Bernard Pichot [SLC] [DevOps Advocate]1.44K 5th January 2024 1 Comment
If a parameter is not part of the alarm template (or disable via a condition in the template) it's displayed in grey in visio.
Is it possible to hide/show in Visio a "Not Monitored" parameter ?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 15th January 2024
Sam Stump [DevOps Advocate] commented 14th January 2024
This is a great question I have been trying to figure out also.
based on the first response so far being not possible I have lodged a feature request for this:
https://community.dataminer.services/new-feature-suggestions/ability-with-shape-data-to-use-alarm-severity-of-a-parameter-ie-not-monitored-if-not-part-of-the-alarm-template/
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 8th January 2024 0 Comments
Hi Bernard,
As far as I know you can only show/hide shapes based on the alarm level of an element, service or view (and not based on the alarm level of a parameter).
