Is it possible to find the element using IP address with engine.FindElements()
Solved2.25K views11th July 2023ipaddress
Trong Huynh [DevOps Advocate]881 21st November 2022 0 Comments
I need to retrieve the element in my Automation Script. I have its IP address. There are a number of documented methods for finding elements using name, id, view etc, but is there a way to find the element using its IP address?
Jens Vandewalle [SLC] [DevOps Advocate]10.00K Posted 22nd November 2022 2 Comments
Hi Trong,
You can do this by using DMS_GET_ELEMENT_ID_FROM_IP (76).
Trong Huynh [DevOps Advocate] commented 28th November 2022
Thanks Jen. This works well.
However, for me it works inside a protocol QAction. When using it inside an Automation Script I get “namespace name ‘DMS’ could not be found” error in the Logs. Not sure why.
Jens Vandewalle [SLC] [DevOps Advocate] commented 29th November 2022
Hi Trong, have you tried by adding using Interop.SLDms;?
