Is it possible to filter by connectivity chain elements?
Solved1.22K views14th July 2023alarms
Bruno Sousa [DevOps Member]669 3rd May 2022 1 Comment
Hello
Is it possible to filter the alarms of a pre defined connectivity chain elements?
Thank you.
Best regards
Bruno Sousa
Marieke Goethals [SLC] [DevOps Catalyst] commented 14th July 2023
As this question has been inactive for a long time, we will now close it. If you want further information, could you post a new question?
Miguel Obregon [SLC] [DevOps Catalyst]22.39K Posted 4th May 2022 1 Comment
Hi Bruno,
I believe you cannot filter the alarms from an element chain. However, when setting up the element chain, you could define which parameters will be taken into account in the chain. When you right click on an element (in the connectivity element), you can select the option ‘Select Parameters…’
In the example above, we select the parameter ‘Analog Parameter 1’. You will see the parameter listed in the block representing the element chain:
Bruno Sousa [DevOps Member] commented 4th May 2022
Hi Miguel
Thank you for the feedback!
The purpose of this filter was to have a quick way to test the connectivity chains..
We would simulate an alarm and have a “filter” to quickly see the if the alarms and RCA are working as expected.
Any suggestion on this?
Thank you.
Best regards
Bruno Sousa
