Is it possible to edit DataMiner visual overviews with other tools than Microsoft Visio?
Solved2.40K views16th September 2020Visio Visual Overview
7
João Pereira [SLC]130 16th September 2020 0 Comments
There are other tools that enable a user to edit traditional Visio drawings; however, is it possible to edit Visio drawings used as visual overviews in DataMiner, for example using the Skyline stencils and Advanced Editing options, with these other tools?
Thank you for your help.
João Pereira [SLC] Selected answer as best 16th September 2020
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.48K Posted 16th September 2020 1 Comment
No, we currently only have support for Microsoft Visio.
Please see the following question for a detailed explanation: https://community.dataminer.services/question/are-there-plans-to-edit-visio-drawings-without-visio-application-installed/?hilite=%27edit%27%2C%27visio%27
Note that it is possible to upload existing Visual Overviews (which are regular Visio files that can include stencils) to other tools and manipulate them there. However, there is no integration for this in the DataMiner software.
The ‘Advanced Editing’ panel is specifically designed for Microsoft Visio. This panel is constructed in DataMiner Cube and is pushed to the Visio application using COM.
João Pereira [SLC] Posted new comment 16th September 2020
João Pereira [SLC] commented 16th September 2020
Thank you Sebastiaan, cheers!
Michiel Vanthuyne [SLC] [DevOps Advocate]4.80K Posted 16th September 2020 0 Comments
Most of the Visio alternatives I have seen are limited to diagram/flowchart drawing, while Visio has a lot more possibilities, and is highly extensible with new shapes. You can find a lot of stencils around the web, while some of the alternatives are limited to an included set of shapes.
Next to that, some of the alternatives only allow creating a ‘static’ diagram, and have poor or no support for shape data. As all of the configuration for use in DataMiner is done using shape data, such alternatives cannot be used to create or edit drawings for use in DataMiner.
Michiel Vanthuyne [SLC] [DevOps Advocate] Answered question 16th September 2020
