Is it possible to display values ​​in bps using standard MIBs?
947 views29th June 2026timeofday
Hiroaysu Nakajima84 29th June 2026 0 Comments
Hello,
Is it possible to display bps by polling IN Octets and OUT Octets every 10 seconds and calculating the difference from the values ​​recorded 10 seconds prior, using the formula `bps = (difference in octets / 10 sec) * 8 bits`?
Alternatively, please let me know if there are any example connectors available on your website.
Thanks.
Hiroaysu Nakajima Answered question 29th June 2026
Pedro Debevere [SLC] [DevOps Enabler]3.52K Posted 29th June 2026 0 Comments
Hi Hiroaysu,
An example connector that implements rate calculation logic can be found on the following GitHub repository: SLC-C-Example_Rates-SNMP.
Pedro Debevere [SLC] [DevOps Enabler] Answered question 29th June 2026
