is it possible to display alarm duration ?
Solved1.23K views11th July 2023Alarm Console
Bernard Pichot [SLC] [DevOps Advocate]1.32K 29th March 2022 0 Comments
In the alarm console there is the severity duration column but this column doesn't display the total duration of an alarm (time between root time and clear time).
Is it possible to get the duration of an alarm in the alarm console ?
Michaël Pincket [SLC] [DevOps Advocate]1.96K Posted 29th March 2022 3 Comments
Hi Bernard,
You can see the total duration of the alarm in the side panel of the alarmconsole. It looks like this :
Bernard Pichot [SLC] [DevOps Advocate] commented 29th March 2022
Thanks Michael,
but when the alarm is cleared the severity duration is N/A and severity duration display the duration for each step (severity) of the alarm history.
Is it possible to get the total severity duration ?
On the side panel the time between () show number of minutes when the alarm start but not the duration of the alarm if the alarm is cleared.
Michaël Pincket [SLC] [DevOps Advocate] commented 29th March 2022
Hi Bernard,
Indeed when the alarm is cleared it is not possible to see the total duration of the alarm.
If you create a new software task we can add this to the alarmconsole as a column.
