Is it possible to define a custom parameter description in a correlation alarm ?
Solved1.24K views11th July 2023Correlation rules
Bernard Pichot [SLC] [DevOps Advocate]1.32K 5th May 2022 0 Comments
When a new alarm is generated in a correlation it’s possible to define a custom Value. Is it possible also to define a custom parameter name ? by default the correlation alarm use the parameter description of the first alarm that trigger the correlation
Rene De Posada [SLC] [DevOps Advocate]1.93K Posted 6th May 2022 0 Comments
Bernard – This is not currently possible in the way you present it here. However, you can make use of custom properties to play with a custom parameter description.
