Is it possible to control parameters used in a visio from a low-code dashboard?
Solved2.18K views10th August 2023Dashboards LowCode Visio
6
Lars von Oertzen [SLC] [DevOps Advocate]371 1st August 2023 0 Comments
Hi!
Is there a way to add control functions from a visio into a low-code dashboard? In this example, I was wondering if I could easily control my IRD within the visio without adding the parameters separately on the dashboard.
It seems that the Visio gadget in the low-code dashboard editor supports read-only…?
THX!
Lars
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 10th August 2023
Miguel Obregon [SLC] [DevOps Catalyst]23.93K Posted 4th August 2023 1 Comment
Hi Lars,
I performed a small test adding a ParameterControl shape data on a overview. When embedding this overview in a dashboard, I am able to perform sets on the parameter:
Have you tried first setting the parameter from Cube? Could it be the case that even in Cube the set is not being performed?
To further investigate, could you let us know which specific share are you trying to use? Is it the toggle button?
Wim Bruynooghe [SLC] [DevOps Advocate] commented 7th August 2023
This should indeed work, however we’ve discovered an issue with this in version 10.3.8 where it doesn’t work anymore. We’ll look into fixing it. (DCP217692)
