Is it Possible to combine two subscription filter ?
Solved1.17K views26th September 2024
Maxime NOEL [DevOps Advocate]104 4th June 2024 2 Comments
Hello, i want to display these parameter status on the visio (8903) and filter to show only the Resumed Capture.PNG
The problem is this table is a partial table, so i want to know if its possible to combine two subscription filter : the ForceFullTable=True to disable the partial table and the Value=8903 == Resumed to filter and display only the Resumed ?? and how can i whrite it
Thanks for your Help.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 26th September 2024
Miguel Obregon [SLC] [DevOps Catalyst] commented 4th June 2024
Hi Maxime,
Maybe I am missing something but checking the documentation, you can combine multiple filters by semicolon:
For the SubscriptionFilter, ParameterSubscriptionFilter and TableRowFilter components, it is possible to configure a dynamic table filter. This filter can consist of the following components, separated by semicolons.
https://docs.dataminer.services/user-guide/Basic_Functionality/Visio/reference/Dynamic_table_filter_syntax.html?q=forcefulltable
Have you tested using semicolons?
Hope it helps.
Marieke Goethals [SLC] [DevOps Catalyst] commented 22nd August 2024
Hi Maxime,
I see that this question has been inactive for some time. Do you still need assistance with this, or have you been able to resolve this? Did Miguel’s suggestion help?
Marieke Goethals [SLC] [DevOps Catalyst]7.33K Posted 26th September 2024 0 Comments
As this question has been inactive for a long time, and there hasn't been any further reaction from you, I have added this pro forma answer so that we can mark it as resolved. If you do still want more information, could you post a new question?
