Is it possible to change the default Engine.Timeout on a dma level?
Solved1.67K views8th July 2021automation scipt
Gellynck Jens [SLC]2.72K 8th July 2021 0 Comments
By default, an automation script has a timeout (engine.Timeout property). Is it possible to override this (through a config setting) so you don’t have to increase this in every script (in case you have many long-running scripts)?
It would be useful if we could change this default timeout for all scripts on the DMA (or even DMS).
Gellynck Jens [SLC] Selected answer as best 8th July 2021
Wouter Demuynck [SLC] [DevOps Advocate]7.07K Posted 8th July 2021 0 Comments
Hi Jens,
There is currently no option to configure a default timeout for automation scripts.
The hardcoded default timeout is 10 minutes.
