Is it possible to alarm ‘Not Initialized’ values?
Solved2.22K views7th January 2022alarm not initialized
Sebastian Ulloa [SLC] [DevOps Advocate]2.24K 6th January 2022 0 Comments
A user wants to know when certain elements are not getting data for a parameter. Would it be possible to alarm a not initialized value, so he can quickly spot those elements?
Sebastian Ulloa [SLC] [DevOps Advocate] Selected answer as best 7th January 2022
Edson Alfaro [SLC] [DevOps Advocate]1.63K Posted 6th January 2022 0 Comments
It’s not possible.
David Pernes [SLC]90 Posted 7th January 2022 1 Comment
Hi Sebastian, if we are not getting data could we consider a regular element timeout capabilities? If a group is not getting the desired reply an element should go into timeout.
If for some reason timing out is not viable/possible for this use case, consider setting an exceptional value on that specific parameter such as “Not Found” or “N/A” and set an alarm template on it.
Sebastian Ulloa [SLC] [DevOps Advocate] Posted new comment 7th January 2022
Sebastian Ulloa [SLC] [DevOps Advocate] commented 7th January 2022
Thank you for the input, I was thinking on a solution that wouldn’t need a protocol modification but I guess there is not.
