Is it possible for a script to update a session variable?
Solved2.12K views18th July 2023
Christian Hanøy [DevOps Member] 3rd May 2021 0 Comments
Hello,
I have an automation script that uses data from a session variable. Once the script has executed I want the data in that session variable to be emptied. How can I do this?
Ive Herreman [SLC] [DevOps Enabler]14.81K Posted 3rd May 2021 0 Comments
Hi Christian,
This is possible for any DataMiner running version 10.0.13 (or later).
The feature was introduced under Release note RN27895
To pass the output values of that script to session variables in Visual Overview you can use the new CreateKey(string variablename) method (namespace: Skyline.DataMiner.Automation, class name: UIVariables.VisualOverview).
In the following example, a session variable named “MyOutput” will be created and will receive the value “MyValue”.
engine.AddScriptOutput(UIVariables.VisualOverview.CreateKey(“MyOutput”), “MyValue”);
