Is InterApp communication compatible with a replicated Element
Solved1.75K views14th July 2023element replication InterApp protocol
Wannes Wittevrongel [SLC] [DevOps Member]165 13th April 2022 0 Comments
Is it possible to use InterApp communication on a replicated element?
Currently, we see the following error on the staging system:
2022/04/13 14:30:22.402|SLManagedScripting.exe|ManagedInterop|ERR|0|120|QA4|4|Run|Exception thrown:
System.TimeoutException: Timeout while waiting on responses: 851338dc-c6fc-4613-bf36-56dd81c6dfa5
   at Skyline.DataMiner.Library.Common.Subscription.Waiters.InterApp.MessageWaiter.<WaitNext>d__5.MoveNext()
   at Skyline.DataMiner.Library.Common.InterAppCalls.CallBulk.InterAppCall.<Send>d__30.MoveNext()
   at Skyline.Protocol.Generic.RequestEventsInformation(SLProtocol protocol, ElementInfoEventMessage element)
   at Skyline.Protocol.Generic.GetEventsFromElement(SLProtocolExt protocol, String elementName)
   at QAction.Run(SLProtocolExt protocol)
On the internal test system, we receive an empty response. When switched to the original element everything seems to work fine.
Jan Staelens [SLC] [DevOps Advocate]924 Posted 10th June 2022 0 Comments
InterApp Calls were never tested using Replicated Elements.
InterApp calls in the background use two technologies:
  • SLNet remote parameter sets
  • SLNet Subscriptions.
If one of those doesn’t function correctly with replicated elements then InterApp Calls won’t work.
I’ve created a task internally to look into adding replicated elements as part of our testing suite and see if we can get it working.
