Is changing of Element Logging Levels Logged?
Solved1.62K views11th September 2025logging logging level
Dave Keller [DevOps Enabler]2.00K 11th April 2025 0 Comments
Is changing the logging levels of an Element logged anywhere apart from in the log file?
If changing the logging level results in a lot of messages, the log message stating when the logging level was changed is lost.
Thanks
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.39K Posted 12th April 2025 0 Comments
This might be an overkill but if you are after the ‘when‘ the setting was applied you can use this log reader connector to check for the specific string and alarm on it.
So while you might not see it in the cube interface it could still be present in the log file itself before it rolls over. No guarantees, of course.  In addition you could “play” around with size of your log files to accommodate more.
Catarina Grilo [SLC] [DevOps Enabler]3.58K Posted 11th April 2025 0 Comments
Hi Dave,
I believe this change is only reflected in the log file of the element itself. There is no corresponding information event, for example.
However, if you go to Cube > System Center > Logging > Elements, you’ll see the configured log level displayed next to each element’s name. That makes it easy to quickly identify which elements are set to a higher log level.
Catarina Grilo [SLC] [DevOps Enabler] Answered question 11th April 2025
