Is a VM running Cassandra with only 16GB for a staging agent sufficient enough?
Solved1.14K views7th July 2023
7
Dominik Kosteletzky [DevOps Advocate]773 1st March 2023 0 Comments
Usually for Cassandra these options should be set in jvm-server.options:
-Xms16G
-Xmx16G
...but with these settings the Cassandra service dies on a VM with 16G RAM total.
Now can this be lowerd for a staging agent or is it really a must to use 32GB RAM on the VM?
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 1st March 2023 0 Comments
Hi Dominik,
This is of course always very specific to the situation, but generally speaking, you should have no issues in a staging environment if you lower the JVM memory settings.
