Is a Virtual IP required for DataMiner Failover?
Solved2.74K views19th July 2023Failover
Cyrus Uible [SLC]50 18th November 2020 0 Comments
Is it possible to setup a DataMiner failover pair WITHOUT a virtual IP.  Use case is to setup a failover pair with each DMA in a different physical location where there is a restriction on the IP addresses used in each location.  So can the failover pair be setup knowing that the IP will change when failing over.
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 19th November 2020 0 Comments
Currently, this is not possible.
However, starting from DataMiner 10.1.2 this will be supported.
Stay tuned...
Ive Herreman [SLC] [DevOps Enabler] Edited answer 19th November 2020
