IR Controller Use Case Examples?
Solved1.42K views20th July 2022IR Control
Jamie Stutz [SLC] [DevOps Member]1.18K 20th July 2022 0 Comments
Has anyone implemented any solutions for IR control via DataMiner? In short, we’d like to send IR commands to devices like TVs at remote locations, like home studios. Has anyone implemented something like this to centrally control the various devices using small IR transmitters devices at each site? If so, can you please point me in the right place to any drivers we might already have?
Thanks!
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 20th July 2022
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 20th July 2022 1 Comment
Hi Jamie,
We have a driver for the RedRat IR Netbox which allows you to send out IR commands controlled by DataMiner.
Jamie Stutz [SLC] [DevOps Member] commented 20th July 2022
Thanks Ive! I did see another connector that was similar, but hasn’t been touched since 2009, so this one looks MUCH more promising. Thanks!
