Integrating SMSEagle with Dataminer NMS
Solved1.28K views8th October 2021
Przemyslaw Jarmuzek 8th October 2021 0 Comments
I’m contacting you because one of our customers asked if there’s an option to integrate SMSEagle as SMS sender into the Dataminer NMS.
I tried searching in the web for it, even tried your live demo, but I’m unable to locate such information. As far as I know you’ve been using few SMSEagle gateways in the past, so I hope you’ve can help us in this case.
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 8th October 2021
Bert Vandenberghe [SLC] [DevOps Enabler]10.12K Posted 8th October 2021 0 Comments
Yes, DataMiner supports the SMSEagle gateway. Therefore you need the mobile gateway option and more info to configure this, can be found in the help.
This is the result in the UI:
