Install Indexing Engine Fails When Checking For System Requirements
Solved1.86K views14th July 2023Elastic
Geovanny Galeano [SLC] [DevOps Advocate]820 25th April 2022 0 Comments
Similar to this question, but for me rebuilding the performance counters didn’t work.
https://community.dataminer.services/question/unable-to-install-elastic-search-as-it-fails-with-elastic-search-recommendation-request-failed/?hilite=%27Cpu%27%2C%27Performance%27
Running DataMiner (10.2.4.0-11673)
Or is there a detailed guide on how to install elastic manually, I’m trying to get an instance of Jobs running.
Marlies Vandenberghe [SLC] [DevOps Member]2.98K Posted 23rd November 2022 0 Comments
In the meantime we have indeed a guide to install elastic manually
Do note that our current recommendation is to install cassandra and Elastic on a seperate Linux VM:
Installing Elasticsearch on a DMA via DataMiner | DataMiner Docs
