Info on BPA CompareFiles
Solved1.22K views23rd January 2025BPA Documentation
Mieke Dryepondt [SLC] [DevOps Advocate]4.27K 5th September 2024 0 Comments
Where can I find info on the CompareFiles BPA?
I would like to know what needs to be done to resolve the errors that can be reported by this BPA.
For example: “ElementID: Entry known by x but not by y: a/b”
It would be nice if the BPA would include a suggestion on how to solve / where to look in it’s result.
Baptiste Pattyn [SLC] [DevOps Advocate]5.86K Posted 6th September 2024 0 Comments
Hi Mieke
normally these are documented here: Running BPA tests | DataMiner Docs.
Note that CompareFiles is not in there (hence your question probably). I looked around and could not find any documentation on this BPA.
I would suggest you create a task for this so it can be picked up.
