Indexing Engine Installation Stuck
Solved2.31K views12th July 2023Elasticsearch indexing engine installer
Aston Galvin [DevOps Advocate]20 20th June 2023 0 Comments
Hi All,
I am attempting to install "Indexing Engine" on a standalone DMA running 10.3.7 with no elements. I triggered the installation from Search & Indexing (System Center), using the offline package (elastic-binaries.dmupgrade).
From all appearances the majority of the installation appears to be complete, Elasticsearch has been installed and configured. I have attempted to reinstall the engine multiple times but it gets stuck at the same point.
It keeps repeating "Waiting for all master nodes to be ready (0 out of 2 are currently ready)" and I can't seem to progress it. I have attempted to see if it would move on if I started the Elasticsearch service, but unfortunately, that didn't do anything.
With Elasticsearch running it appears to be happy, but not sure if there is an underlying config issue preventing it from progressing.
Any help will be greatly appreciated.
Marieke Goethals [SLC] [DevOps Catalyst] Answered question 30th June 2023
Marieke Goethals [SLC] [DevOps Catalyst]7.75K Posted 30th June 2023 0 Comments
Hi Aston,
Have you been able to solve the issue with Arunkrishna's answer? If so, could you select the answer (using the ✓ icon)? If not, you can also contact techsupport@skyline.be for assistance.
