In automation script, how to get Resource details from Device IP
Solved1.92K views20th June 2024#automationscript Automation DIS Automation script solution automion script
Baranisudha Murugesan [DevOps Member]1.19K 14th June 2024 2 Comments
I will get a list of device IPs from postman calling a API trigger in automation script. I want to extract Resource details from the Device IP im getting. Do we have any extension methods to get?
So below are the resource details i have in hand.
  • "10.130.119.34"
  • "03ea386d-f8fd-4891-a2f4-b77491bca7aa"
  • "Demodulator"
So the expectation is to get the element details from the information i have.
Baranisudha Murugesan [DevOps Member] Selected answer as best 20th June 2024
Peter Vanpoucke [SLC] [DevOps Advocate] commented 18th June 2024
hi
Could you elaborate on how the resource is linked with the IP and what details you would need from the resource? Perhaps adding a screenshot to your question might give a hint.
Baranisudha Murugesan [DevOps Member] commented 18th June 2024
I have updated the question with extra details
Jorge Dias [SLC] [DevOps Enabler]5.36K Posted 18th June 2024 3 Comments
Hi Baranisudha,
Please check the reply from question Is it possible to find the element using IP address with engine.FindElements() - DataMiner Dojo.
From there you will have a string with a list of dmaId/elementId separated by ';' that you can use to find the element details.
var ids = globalElementID.Split(',');
var elements = new List<Element>();
foreach (var id in ids)
var aux = id.Split('/');
var dmaId = Convert.ToInt32(aux[0]);
var elementId = Convert.ToInt32(aux[1]);
var element = engine.FindElement(dmaId, elementId);
elements.Add(element);
From there you have a list with all elements that use the provided IP, you just need your logic to return the data that you need.
Baranisudha Murugesan [DevOps Member] commented 20th June 2024
i have tried this method, but i couldn’t achieve it because the Notify method is deprecated.
DMS dms = new DMS();
dms.Notify(type/*DMS_GET_ELEMENT_ID_FROM_IP*/ , subType, ipBus, null, out result);
Error message we are receiving —
Script Failure (Sky_Create_Service): (after retries) (Code: 0x80040251) Skyline.DataMiner.Net.Exceptions.DataMinerException: No Assembly found for cookie 10
(123,4): error CS0246: The type or namespace name ‘DMS’ could not be found (are you missing a using directive or an assembly reference?)
But I have referenced DMS.
Jorge Dias [SLC] [DevOps Enabler] commented 20th June 2024
Is not a problem the Notify to be deprecated.
Can you add C:Skyline DataMinerFilesInterop.SLDms.dll to DLL references of your script? Add using Interop.SLDms; in the code?
Yes this works. Thank you!!
