In Alarm Console, how do we filter out blank cells?
Solved3.91K views10th September 2021Alarm Console alarm filters
Steve Purcell [SLC] [DevOps Advocate]2.69K 9th September 2021 0 Comments
We want to be able to use the Alarm Console filter (services:) to only show alerts where the services field is populated.  We have tried different entries (services:!"", services:*), however, the alarms with the Services column blanks continue to appear.  Is there a way to set the Alarm Console filter to filter out blanks?
bruno santos [SLC] [DevOps Advocate] Answered question 10th September 2021
Ive Herreman [SLC] [DevOps Enabler]14.79K Posted 9th September 2021 1 Comment
Hi Steve,
While this doesn't answer the question of how to filter out empty cells, you should be able to filter out alarms that impact a service by using:
"Service impact":>0
Steve Purcell [SLC] [DevOps Advocate] Posted new comment 9th September 2021
Steve Purcell [SLC] [DevOps Advocate] commented 9th September 2021
Thank you Ive, this worked great at the quick filter level.
